Hi everyone!
Solved by blair. Go to Solution.
I am not sure what you are asking.
Do you want to bend that part into a 360° arc (Bend Part) command to wrap into a cylindrical shape?
Maybe something like this?
What do you want as the finished inside diameter?
Can you attach your *.ipt file here?
Yes, that I'm talking about.
I attach a similar geometry
I found the appropriate function, but it is possible only wrapped about 180, but I do not have the possibility of setting the radius of 360 degrees. however, I worked it out with the cutting model in half and wrap each parts of 180 degrees, and then the two parts joined in a common cylinder
I am grateful for the help.
best regards
TJet
