Inventor Forum
resetting dimensions
3 REPLIES 3
bengee54
335 Views, 3 Replies
I'm using Inventor 2010.
i've got a model of which i'm producing a drawing, but when i add the dimensions - they appear all over the place. my thinking is that perhaps i've got to reset the UCS or something. - its as if the dims are on the wrong plane.
anybody help?
3 REPLIES 3
mcgyvr
in reply to: bengee54
Please post a screen shot..
Are you just manually placing dimensions? Or trying to use the automatic dimensioning?
bengee54
i was placing the dimensions manually.
attached is the requested screenshot.
thanks.
Martin_Goodland
If you right click on the view and go to 'General Dimension Type' is it currently set to TRUE ? If it is set it to PROJECTED instead and try adding the dimensions again.
This will happen if your drawing view is not Normal to the part / assembly work planes Inventor assumes you have placed an ISO view.
Regards
Martin
Inventor 2023
