Interesting, never knew these options were there. Can you point me to any more info or documentiation on exactly what all the DAcc options under RMB > component are and what they are actually doing?
I see, Calculate, sovle off, manual solve and automatic solve.
Whats the difference between calcualte and solve? or setting it to automatic vs manual solve?
I have a similar problem. I have a sub-assembly that is bolted to one sub-assembly on one and and another sub-assembly on the other. I always had at least one red ligntning bolt. If I simply edit the connection with the DAcc the Lightning bolt on that connection goes away but the other lights up. Both will not go away. I tried the Automatic Solve suggestion and i no longer have red lightning bolts (it puts a different symbol permanently where the red bolts were) but the overall update button (yellow lightning blot) at the top of the screen remains lit. I can not get all of the update lightening bolts (either red or yellow) to go away.
Any other suggestions?
