You can get so close you can almost touch it.
The Rectangular Pattern command will allow you to pattern along a path of
which it will report the length of that path in the dialog.
But, alas, the reported distance does not exist as a parameter.
QBZ
"dcharville" wrote in message
news:28464401.1111442214932.JavaMail.jive@jiveforum1.autodesk.com...
> Has anyone ever tried to get the result of a "measure loop" command from a
> sketch into a user defined parameter? Pro/E used to have an option that
> allowed you to do something similar if I recall correctly. I think it was
> called a "measure parameter".
> Thanks,
> Dustin Charville
> Fujitec America Inc.
