Inventor Forum
"Use color override from source component" reverts to default intermittently
18 REPLIES 18
Message 1 of 19
eucci
1950 Views, 18 Replies
I regulary (almost exclusively) model complex designs with a multi-bodied source ipt file. Then, I use the "make components" commant to create an assembly of all the bodies. Universally, I want to control material, appearance, part no, etc,etc. from the BOM in the assembly. Unfortunately, for the last few years, there has been a bug wich takes the "use color override from source component" check box and reverts it back to it's default setting which is checked. This happens intermittantly and if gone unnoticed, requires that each individual ipt file in an assembly be opened, edit derive part, and uncheck the box. I never have a reason to check this box. I universally prefer that it be unchecked. Unfortunately there is way to make a global change to this setting. In addition, a derived part can revert back to the "checked" state upon a rebuild.
Is there any way to avoid this?
Thanks in advance
18 REPLIES 18
Message 2 of 19
eucci
in reply to: eucci
just doing this to move it back up the list
Message 3 of 19
johnsonshiue
in reply to: eucci
Hi! There is a registry switch to set the option off by default.
Close Inventor and find the following registry key.
Go to "HKEY_CURRENT_USER\Software\Autodesk\Inventor\RegistryVersion1x.0\System\Preferences\PartDerivedPartDlg\"
Add a key “InitialColorOverride” and set its value to 0.
Thanks!
Software Test Engineer
Message 4 of 19
eucci
in reply to: johnsonshiue
Johnson,
thanks. I'll give it a try. If I go a week with no troubles I'll accept as solved.
Message 5 of 19
eucci
in reply to: eucci
Johnson,
I created the registry key as you suggested. No change in behavior. Derived parts ar still reverting back to checked status.
Message 6 of 19
johnsonshiue
in reply to: eucci
Hi! What release of Inventor are you on? R2014 or R2015?
Message 7 of 19
eucci
I'm in 2014. I'll be moving to 2015 any day. Is this corrected in 2015?
Message 8 of 19
johnsonshiue
in reply to: eucci
Hi! It should work. It works on my machine. Have you installed R2014 SP2? Could you take a snapshot of the registry I showed you? I want to see how you set up on your machine.
Thanks!
Message 9 of 19
eucci
Johnson,
See registry snapshot attached
Message 10 of 19
eucci
in reply to: eucci
And, yes, I have sp2 installed
Message 11 of 19
johnsonshiue
in reply to: eucci
Hi! I see where the problem is. I am sorry it was my fault giving the wrong instruction. "InitialColorOverride" is not a key. It should be a DWORD and set the value to 0.
Please let me know if it works.
Thanks!
Message 12 of 19
eucci
can you show be a snapshot of what that looks like?
Message 13 of 19
johnsonshiue
in reply to: eucci
Hi! Please see the attached image. Thanks!
kelly.young has embedded your image for clarity.
Message 14 of 19
eucci
Johnson,
After a week w no troubles, I can say problem solved!
Thank you very much!
Message 15 of 19
eucci
in reply to: eucci
I'm having the same problem in INV 2016
Inv Pro 2016 64 bit
Build 236, Release 2016 SP2 - Date Thu 04/21/16
Can you give me instructions for this version?
I expect to be posting again after I upgrade to 2017 in  the near future.
Message 16 of 19
sjxyz
in reply to: eucci
It's ticking itself for me in the Application Ooptions still in 2017! Tried the registry fix, which didn't seem to help. Any update on this would be welcome...
Message 17 of 19
andrewdroth
in reply to: sjxyz
Yeah, 2018.2. How do we fix this?
Andrew Roth
rothmech.com
YouTube IconLinkedIn Icon
Message 18 of 19
eucci
in reply to: andrewdroth
Andrew,
2018 has a setting in Application Options.
I have found that it is now reliable once you un-check the box.
Message 19 of 19
andrewdroth
in reply to: eucci
Awesome! Thank you!
Andrew Roth
rothmech.com
