Inventor Forum
"No visible, unadaptive sketches" message
3 REPLIES 3
2255 Views, 3 Replies
My .ipt file has a shared sketch that is visible and not adpitive.
But When I attempt to make a second extrution from the sketch, a message says, "No visible, unadaptive sketches".
I could create another sketch, but I want to learn how Inventor is woking becuase I have had this error before.
The file is attached (I am trying to extrude from the "binder" sketch).
Thank you.
3 REPLIES 3
cwhetten
I just tried it and it worked for me.  Although in the part you attached, the binder sketch was invisible, so I had to make it visible first.  But I don't know why it won't work for you...
Cameron Whetten
Inventor 2012
samiharada
Turn visibility on first?
I see both "tube" and "binder" are invisible - the message says "No visible, unadaptive sketches"...
-Sami Harada
Inventor framework QA
Autodesk, Inc.
in reply to: samiharada
Now I understand; "visible" doesn't just mean I can see the sketch, it means "Visibility" has a check mark.
Thank you for getting me through this newbie question.
