Inventor Forum
quadrant constraint in sketch mode
5 REPLIES 5
701 Views, 5 Replies
i currently use 2010 inventor and i am trying to do a quadrant constraint with a point, is this possible???? i cannot figure it out..
5 REPLIES 5
CCarreiras
Hi!
Can you explain Better?
Regards.
CCarreiras
JDMather
Can you use a Horizontal or Vertical or add a Construction line?
There is no Quadrant constraint.
in reply to: JDMather
yes it is possible for me to use lines, i was just curious if it was possible to do it without doing that.... i wasnt sure if there was a constraint option that i might be overlooking or something....
JDMather
I use more construction lines now than I have since leaving the drawing board in the last century.
I often create construction lines even when they aren't technically needed because it helps me a year from now (OK, next week) figure out what I was doing if (OK, when) I have to go back and edit the sketch.
thanks for your help, i have started using them more then i use to, but mostly when doing sketches in autoCAD....  ill have to try it in Inventor sketches as well
