Solved by schnautza. Go to Solution.
To attach
Simply click the "Choose File" button. navigate to the file you wish to attach.
Click open.
To insert..
hit the "insert/edit image" button.
hit the choose file button when that dialog window comes up.then insert image.
Its VERY simple.
Works just fine for me (using Chrome).. But I've used the internet before 🙂
I had that problem using Firefox. I also have web page formatting issues with this forum in Firefox. I have to use the Internet Explorer to get it to work properly.
So you don't see any of these buttons? (see attached image)
Are you on "Rich Text" and not HTML or Preview
Are you running with any kind of Compatibility view? I initially had some similar problems at first when that was set.
@schnautza wrote:
I swear I didn't change any settings between that post and the previous one.
SSUUUURREEEE you didn't 🙂
The internet is sometimes a bizarre beast with a mind of its own. Now it has made me look like a crazy person in more than one thread on these forums.
Is it bad of me to accept my own post as the solution...since it was just my computer being weird?
Check out that you don't have MauCampo virus - which is an add ware. Just have a look in your Program Files folder to see if you have a folder with such a name. If you do - remove it. Get advise from the Internet how to do it.
Best Regards,
Igor.
@schnautza wrote:The internet is sometimes a bizarre beast with a mind of its own. Now it has made me look like a crazy person in more than one thread on these forums.
My machine at still doesn't like this new forum. I still can't insert pictures or attached documents. The problen exists on IE10, IE11, Firefox and Safari with my work machine. It was working fine before the push to the new forum.
It will strip all formating and blank lines and put everything into one paragraph.
