Inventor Forum
problem create flat pattern with punch
1 REPLY 1
185 Views, 1 Reply
Hello, i have problem when i'm creating flat pattern from this sheet with punch... how to make that punch contur be in same position in flat pattern... Because first need cut then make punch... O when i'm create dxf file hole in flat pattern is same like i do in 3d, but have to be smaller... adding file
1 REPLY 1
mdavis22569
It's creating a flat pattern in the software ... however it just won't eliminate the punch that have you in there. You may have to do your flat pattern and export in 2 stages. One with the hole in it ..then with the punch added. I tried a few different punches and they all stayed the same in flat pattern. I even tried putting a hole in and trying to add a flat/chamfer to see if I could recreate the part that way and couldn't.
Mike Davis
