At this time, we do not support overlay section views. This is a technical
limitation, and we hope to provide this functionality in the future.
As far as occlusion of overlay geometry behind primary geometry, that just
simply isn't on our radar. The notion of "hiding" overlay view geometry
behind primary geometry is not something we support, and I'd be reluctant to
provide that functionality without a lot more feedback.
I think, based on what you're describing, that you can accomplish your goals
(sectioning and occlusion) through modeling techniques. I've attached a
sample drawing example and a snapshot of my Inventor session to show how I
got there.
Basically, I just created a dummy (wrapper) assembly and constrained 2
versions of the U-shaped assembly together. Creating a drawing view of that
provides the occlusion functionality. I then derived that assembly into a
part and split the part at the center to achieve the sectioning solution.
Hope that helps,
Andrew Faix
Product Designer
Autodesk Inventor
wrote in message news:5579661@discussion.autodesk.com...
So what I have right now is four positional representations of this part.
It is technically an assembly, an will eventually have more parts, but for
my purposes it was easier just to have the one part in an assembly for now.
So there is an overlay view on the left, and an overlay view on the right.
The two interior views are the base views, and the two outermost views are
the secondary views.
So the first thing I'd like to do is to section the outermost views along
their centerplane
s so that you can see inside the part.
The other thing I'd like to do is hide the lines on the secondary views, but
only where the base view looks like it's in front of the secondary view.
Let me know if this helps, and thanks again.
