So i have a few rectangle's, to explain this i made (verry fast) the image below.
Say that i wanna replace all holes with rectangles how do i do that?, also i want them to point away from the circle.
For this i used arc's, but how can i say that 10 in this case holles (rectangles) in one arc?
I created the rectangles sepperatly and was planning on adding them in the assembly, this should be good right?
Thanks in advance
Post your file (ipt) and the version of Inventor used.
Since none of your sketches are constrained, I have no idea what your intent is, but this might help.
You might read this document http://home.pct.edu/~jmather/skillsusa%20university.pdf
The CADWhisperer YouTube Channel
