HI
One of my customer is using Autodesk Inventor 2009, windows XP
He has a problem with the ''place from content center'' dialog, it suddenly missing all the content library from the dialog box but it worked fine on the day before this.
Please refer to the attachment
Any ideas why this should suddenly happen?
dotnet framework issue?
What is really interesting I find is that the OP has not responded at all. Does anyone know if ANYTHING in this thread has solved HIS issue?
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Good point,... I got so into this I forgot that ASCO was NOT the OP!
Still hoping we can help both of these guys.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Due to other processes that should not be interupted we have automatic updates disabled and we do this manually every now and then. It is a valid suggestion though, especially if you have custom startup routines on the server.
Thanks for the input,
Misha
@ASCO-engineering wrote:Hi,
Misha
No problem, wish I could do more.
Chris Benner
