Inventor Forum
place from content center dialog issue
23 REPLIES 23
Message 1 of 24
weiloon
1172 Views, 23 Replies
HI
One of my customer is using Autodesk Inventor 2009, windows XP
He has a problem with the ''place from content center'' dialog, it suddenly missing all the content library from the dialog box but it worked fine on the day before this.
Please refer to the attachment
Any ideas why this should suddenly happen?
dotnet framework issue?
23 REPLIES 23
Message 21 of 24
Cadmanto
in reply to: cbenner
What is really interesting I find is that the OP has not responded at all.  Does anyone know if ANYTHING in this thread has solved HIS issue?
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 22 of 24
cbenner
in reply to: Cadmanto
Message 23 of 24
ASCO-engineering
Due to other processes that should not be interupted we have automatic updates disabled and we do this manually every now and then. It is a valid suggestion though, especially if you have custom startup routines on the server.
Thanks for the input,
Misha
Message 24 of 24
cbenner
in reply to: ASCO-engineering
Misha
No problem, wish I could do more.
