Hi
The part attached is a large size file due to the use of pattern features.Is there a overlay similiar that i could use so as to cut down the file size?
Please pull down EOP
IV2013
Have you tried the same part using a Punch in place of the Hole and Revolution?
Have you considered pattern Body rather than pattern Feature?
Just following up your responce
When you say pattern body do you mean make 1 segment then pattern .. i attached a file...just split for ease of sample....
Would i need to create a custom punch for that particular shape?
If i do create a punch can this punch be saved to my favourites folder or do punches need to be saved to a folder with in Inventor?
