Inventor Forum
part out of a picture or logo ???
10 REPLIES 10
Message 1 of 11
287 Views, 10 Replies
How do you make a part out of a picture or logo. We have a plasma and would like to make company logos or some designs. How do you get it from a jpeg or bmp to a sheet metal part. -- Lester Martin
10 REPLIES 10
Message 2 of 11
You should be able to use a good paint program to TRACE the edges and get that into DXF format. I know COREL can do this. Once in DXF, I'd send directly to the plasma. -- Rui "Lester Martin" wrote in message news:41c34ffa_1@newsprd01... > How do you make a part out of a picture or logo. > We have a plasma and would like to make company logos or some designs. > How do you get it from a jpeg or bmp to a sheet metal part. > > -- > Lester Martin > > >
Message 3 of 11
Can you save as DXF in Corel?
Message 4 of 11
Last version I used was Corel 5 and you could then, so I'm assuming a current version still can. Maybe even some ADOBE (I'm thinking Illustrator or something like that) format can be converted but I'm not familiar with ADOBE. -- Rui "Lester Martin" wrote in message news:41c355dd$1_3@newsprd01... > Can you save as DXF in Corel? > >
Message 5 of 11
Coral Draw has an add-on called OCR Trace. You will have to clean it up afterward, depending on the geometry. It will produce a lot of short line segments that cause the burn table to jerk around. It can also produce a lot of arcs smaller then your kerf. "Lester Martin" wrote in message news:41c34ffa_1@newsprd01... > How do you make a part out of a picture or logo. > We have a plasma and would like to make company logos or some designs. > How do you get it from a jpeg or bmp to a sheet metal part. > > -- > Lester Martin > > >
Message 6 of 11
Sorry, I forgot to say that you then save-as a DXF file in Coral Draw. "Doug R. Smith" wrote in message news:41c35624_3@newsprd01... > Coral Draw has an add-on called OCR Trace. > You will have to clean it up afterward, depending on the geometry. > It will produce a lot of short line segments that cause the burn table to > jerk around. > It can also produce a lot of arcs smaller then your kerf. > > "Lester Martin" wrote in message > news:41c34ffa_1@newsprd01... > > How do you make a part out of a picture or logo. > > We have a plasma and would like to make company logos or some designs. > > How do you get it from a jpeg or bmp to a sheet metal part. > > > > -- > > Lester Martin > > > > > > > >
Message 7 of 11
I was able to get it to this point in PSP but I PSP doesn't have a DXF export. -- Kent Keller Autodesk Discussion Forum Facilitator "Lester Martin" wrote in message news:41c34ffa_1@newsprd01... > How do you make a part out of a picture or logo. > We have a plasma and would like to make company logos or some designs. > How do you get it from a jpeg or bmp to a sheet metal part. > > -- > Lester Martin > > >
Message 8 of 11
Message 9 of 11
Turbocad is a cheap and effective answer to this..... Less than £10 from ebay, it has raster to vector translation and works well. also can save as dxf or dwg. Derek "Lester Martin" wrote in message news:41c34ffa_1@newsprd01... > How do you make a part out of a picture or logo. > We have a plasma and would like to make company logos or some designs. > How do you get it from a jpeg or bmp to a sheet metal part. > > -- > Lester Martin > > >
Message 10 of 11
Thanks for the replys I have to see which is the best way for me to go.
Message 11 of 11
henryanthony
Adobe Photoshop will outline a selection. The higher the resolution, the more accurate will be your outlines. Outlines can then be pasted into Adobe Illustrator. Illustrator exports DWG and DXF.
