Whenever I use a control panel - such as EXTRUDE OR CONSTRAINTS - it disappears from view. I can mouse over it and it will show bits and pieces as I pick but doesn't show up
I have un-installed and re-installed the system.
It used to run just fine but have been fighting it for the last year, then a final re-install 3 days ago - no change in problem, but actually it is a little worse.
Makes no difference if it is the only program running or AutoCAD is running also.
It is Inventor 11
It is on Windows XP
NVidia GeForce 4 MX 420 Video Card
All this was a matched set when new and nothing has been updated to newer equipment that would cause a mis-match.
Try going to Tools>Application Options>Hardware tab and set on lowest setting.
Have you updated your Graphics Card?
All Service Packs and Hot Fixes (Updates)?
Yes - Updated driver - still the same problem.
Did all the "normal" stuff.
Checking to see if anyone else has this problem and to see if they found a fix that worked.
@dannyc2 wrote:
It is Inventor 11
Given that Inventor 11 is nearly 8 years old - you might have trouble finding relevant information for your problem.
Not sure how you are (re)activating the license, but I recommend
Reformating the HDD to OOTB condition.
Install all Windows updates for your version of OS.
Install graphics card updates.
Install and run MS Excel.
Install Inventor.
