Hello are using an Italian engineer inventor 2014 on the windows 8.1 after upgrading it happens that opening a file from a folder I have the simultaneous opening of more inventor.
that happened to me before opening the file viniva open various files in the current session.
I asked for help but does not know how to help me answer.
Hello, welcome to the group.
Am I hearing you correct that you are opening files from Windows Explorer, and getting a new session of Inventor each time? I have to ask, why do you not open them from Inventor?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Welcome to the forum.
I agree with Chris. You should open up a session of Inventor first, then using the open icon, open up your files.
When you open up your files from Windows explorer, you could be double clicking too fast, but for the system to be opening up a file in the default program it has associated with that file and opening up the program each time is not specific to just Inventor. MS Word and Excel will do the exact same thing.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Hi
I usually do so I open a file and opens the Inventor if I open a file opens another inventor.
I find it best to open the files from the folder because I use a command less and are faster in search of the file.
We understand what you are saying and we understand the problem you appear to be having.
All Chris and I are saying is in order to prevent this, try what we have suggested and see how it works.
You know the definition of insanity? Doing the same thing over and over again and expecting different results.
Try not to left click on the file 1st just right click and hit open..
A client's engineer had the same issue but what I found is sometimes when he left clicks the file 1st it does a double left click he was unaware of it but after telling him to just right click no left click on the file he had no more issues..
Reason : All programs if left click to select 70% of the time a double click happens (more if mouse is old) when using double click this tells windows to start a new session of the program even if one is open.. If you right click the file there is never a chance of a left double click..
P.S. never start a program from explore.. Always start the program before hand..
Reason : When starting a program from its file type AKA double click file to start program you have more of a chance windows not turning everything on in the registry and run into performance issues and commands not working...
