Have attached a simple assembly..i have constrained the parts but how do i get the shaft/Fan to spin inside the case?
Solved by JDMather. Go to Solution.
Do you mean you want to shaft and fan to spin together? If so.. mate constrain the xy origin plane of the shaft with the xy origin plane of the fan
Then when you "spin" either one they both move together..
Thanks...done
Now is there a way to have the shaft/fan spin by applying some sort of button.Press the button (or other means) and then watch it spin around
Add an angle constraint between the shaft and the grounded part (case) and then Drive Constraint.
