Inventor Forum
motion along a drivetrain
1 REPLY 1
dwpbemis
151 Views, 1 Reply
I have constructed a simply drivetrain (driveshaft,differential, and axles) and used angular motion constraits so they all should rotate properly. Once they are all constrained, I go to rotate the driveshaft and only some of the parts rotate properly. Does the order in which I constrain the parts matter? I know that I have constrained them properly, because I have done it several times and it has to be right. Whatever part I rotate, it always rotates the next part, but then that part doesn't rotate the following part. Thanks for the help.
1 REPLY 1
in reply to: dwpbemis
Can you post to customer files.
A helpful tool for multiple drive constraints is animator. Can be found at http://www.sdotson.com
