good evening to all
for a study that I have to do, I did run a company specialized a 3D scan of some engine parts. Files that have given me are .stl that I can not modify or edit with invetor ...so my question is: how can I make these stl files like editable solids??is it possible convert stl to ipt??
thanks
Hi giulio.tamagnini,
You can use this addin to import STL files:
http://www.youtube.com/watch?v=GdhdgpnFRzw
I hope this helps.
Curtis
Thank you for your quick reply,
Yes, I've tried following that guide, but at the end of the conversion I get a report of the proceeding but of the converted file there is no trace. I also tried to use Autocad 3ds Max, but the file that i get is an assembly file and not an .ipt
Have you contacted the creator of the addin about this?
If you look at the link you'll see a Cust. Support email address.
I hope this helps.
Curtis
STL format is the mesh data which can only view but not edit. Please try to download the Mesh Enabler tool from Autodesk Lab: http://labs.autodesk.com/utilities/inventor_mesh to convert the mesh features to Inventor Base features. The resulting Base features can then be used for further operations including drawings and measurements. This tool is free.
Kevin-Hongyuan Li
Quality Assurance Team
Autodesk, Inc.
The labs link is no longer available and the exchange app is subscription only. I am having the same problem but being an educational institution we do not have a subscription so I guess I'm dead in the water.
You can email Scott Shepard.. He should be able to get you a copy.
