Inventor Forum
mirrored then why does it appear slightly off?
4 REPLIES 4
chad38
1702 Views, 4 Replies
I was attempting to save some time on this part so I decided I was going to copy and paste a profile from a dwg of it. I placed the profile on one of the sides of my contour flange, and created a face out of it and added a bend relief. Then I mirrored these features to the other side about one of the origin planes. However, I spin the part around, and it doesn't appear as though it's mirrored correctly, it looks slightly offset from the sketch. Don't know if you can tell in the below image. I've attached the ipt as well. Any ideas?Capture.JPG
HP Z420 Workstation
Intel Xeon CPU E5-1603 0 @ 2.80 GHz 2.80 GHz
12.0 GB RAM
Windows 7 Professional 64 Bit
3D Connexion Space Pilot
Solid Edge ST9 MP1
Inventor Professional 2015
Autocad 2015
SolidWorks 2015
4 REPLIES 4
JDMather
in reply to: chad38
I couldn't find anything wrong?
Can you create some geometry - a workplane or something that would show the non-symmetrical result?
Are you judging by eyeball of graphics resolution?
chad38
in reply to: JDMather
Can you not see how the sketch elements are thicker on the left side, and get thinner on the right? And yes, I am basing this on the appearance. The circles do not appear concentric. This is the first time I've seen it do this, Usually uniform thickness of lines and circles etc.
HP Z420 Workstation
12.0 GB RAM
Solid Edge ST9 MP1
Autocad 2015
SolidWorks 2015
JDMather
in reply to: chad38
@chad38 wrote:
. The circles do not appear concentric. ..
Appear?  Or are not?
Create axis through both holes - do they line up (stretching out will show even tiny mis-alignment).
Start sketch on the XY plane and Project Geometry all four edges of the holes.  Any difference?
I think you are seeing imprecise graphics - the geometry is fine.
I think part of this is an artifact of shading of the faces to make them easier to see.
chad38
Neat tricks. I suppose it was just an appearance thing. Thanks
HP Z420 Workstation
12.0 GB RAM
Solid Edge ST9 MP1
Autocad 2015
SolidWorks 2015
