can someone please tell me what causes the mass error for 'part 09' in the attached pic?
please tell me how to fix it
it happens on occasion
this time it happened in a derived part that i mirrored as-derived
thanks ... chris
iv2010suite
Possibly the link with the Derived part might be the issue. I would try to open the Derived part by it's self and do a rebuild and see if the mass is correct. Then open the assembly and do a rebuild and then check if it's correct.
thanks Blair.
I tried that and a bunch of other things.
nothing worked.
this has happened to imported step files too.
... chris
Possibly the imported files are not a true solid, but could be a surface model which would explain their small mass (in this case next to nothing).
