Inventor General Discussion
Valued Contributor
will_hebden
Message 1 of 2 (136 Views)
large assembly - very strange problems????
136 Views, 1 Replies
11-04-2008 05:43 AM
I am working on a very large assembly of a lift (2500+ parts) which is causing some strange problems.
Firstly, after opening the assembly none of the buttons work, this includes every button within the inventor environment (file, tools, constraints, measure, rotate, zoom, etc, etc, etc. (note: all the buttons click as normal but nothing happens, except the view buttons (zoom, pan, rotate etc) as these are grayed out?)
Secondly, when i click the RMB, it only shows a few options, (delete, turn visibility on/off, find in browser, open, edit etc), are all missing
Thirdly, This causes my whole windows explorer to not work correctly, i can open programs, but not files, ie i can open Radan (2D CAD program) but cannot open any files, same with internet explorer, it will open but just shows a blank screen.
And lastly!! I have a spaceball with a programmed button for measure, when i click this an error message appears saying "an invalid argument has occurred"
myself and a colleague have both had the same problem on similar assemblies (which use the same components) on different computers
Any help would be greatly apreciated
Regards
Will H
*Expert Elite*
JDMather
Message 2 of 2 (136 Views)
Re: large assembly - very strange problems????
11-04-2008 06:20 AM in reply to: will_hebden
>And lastly!! I have a spaceball....
Since this is happening on different computers this suggestion might not be your solution - but I have found similar behavior is cured by clicking Recalibrate on my 3D Connexion device Control Panel. I've gotten in the habit of doing that every morning. You might also try unplugging it and rebooting Inventor.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
