Inventor Forum
knurled material not working
3 REPLIES 3
safiredesignengineers
508 Views, 3 Replies
Hi Group
in inventor 2013 I select a face and change the material to knurled but nothing seems to happen? does the knurled effect not work?
regards Adrian
3 REPLIES 3
Select Face, then select the "Appearance" icon, then select the correct item, then use the little "up" arrow to apply, or the "up arrow and edit" to apply and open the material appearance editor.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Hi  that works, I was able to apply the Knurl to the face however doing it the way you have suggested enabled me to see that it was down to the scale settings, basically the knurl was too big.
however the max scale i can use is 5 and this is still too big. is there a way to make this pattern smaller?
regards Adrian
You might hunt through the different Material Appearances, both Inventor and the Autodesk. I believe there is more than just one Knurl in the lists.
Delta Tau Chi ΔΤΧ
