Hi All,
I want to join two plates with 6 screws so I used the insert constraint to insert the screws on the first plate so that the next step would be inserting the 'left-over' screw from this plate+screw assembly into the second plate's holes and therefore joining both plates but I am not sure how to go about this properly. The only way I can think on doing this is by alligning the holes of both plates and then using the insert constraint but this does not feel right because inventor will only know that I inserted 1 screw not the other 5. I tried doing one screw into the second plate with the insert constraint, and then repeat with the next screws but an error appeared. Is there a way to apply the insert constraint simultaneously on multiple screws so that Inventor knows that I want those screws to be inserted?
Attached are the two plates that I want to join: the top plate connected to a shaft has the 6 screws inserted using the insert constraint, the bottom plate is the what I want to join it with. All the threads are the appropriate ones.
thanks!
Solved by admaiora. Go to Solution.
You can't use constraint in a multy way.
You can use the insert constraint, then repeat the command for other parts.
If you have an error, probably the software can't do what you want due a geometric error (no axial holes..).
You can use multiple constraint using iMate, but it's not necessary in your case.
Can you attach the 2 parts?
Admaiora
Ok here are parts in a zip file: Both plates and the screw I'm using. The plate with the shaft has the holes going through all the material but in the second big plate the holes only go into the plate about 3 cm, not through all.
So how would I go about this?
Thanks for your help!
Sketch 4 of "Bearing Head" is no fully constraint. As you can see the circle is free to move, in fact it is not in the right position, almost but not the right.
Sketch has to be (normally) fully constrained to have a solid 3d design.
The same for sketch 3 of "Prop shaft".
The dimensions are not congruent between them too.
Here a video to how fix that
You have to fix the external holes pattern, because clearly may they have a problem.
Admaiora
You are welcome Nac.
Maybe you can be interested in this tutorials
Sketch Constraints
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-5AE920BF-8706-4B94-8055-AC741F88D914
Modeling Parts
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-018ED989-9B33-436C-842A-0AB4A4590E76
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-F57ADA16-61FE-4EFD-B25C-490AEC8352F3
Creating Assemblies
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-6D74B0F2-8959-4106-B1CC-444AA8D13DB7
Here you can find tutorial data set too:
For release 2014
and 2013
Admaiora
It is the same. Insert constraints both axis/axis and plane/plane at the same time.
Admaiora
Once I redrew the part with exact dimensions everthing was wonderful.. Why cant I have a tolerance factor for the alignment. I was off by an acceptable number and I still had to have it exact.. I'm new to acad inventor and it drove me nuts for a while untill I found this thread. Thanks
