This happens every time I save as to dwg, it's very annoying.
Does anyone know what's going on?
Thanks for reporting the issue and for the dataset.
I have verified the issue logged it under #1502052 and sent to the development team.
Ladislav
Thank you. Please let me know if any soulution is found.
Another reason everything should just be in metric I say.
Could it be as simple as the dwg template you are using? Maybe the default dim style in your template dwg is set to 4 place decimals? Just something to check, anyway.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
