Inventor Forum
ilogic shortcut key
61 REPLIES 61
Message 1 of 62
Ktelang
9010 Views, 61 Replies
ilogic shortcut key
Is there any command/option to add a keyboard shortcut for ilogic rule ?
Config :: Intel (R) Xeon (R) CPU E31245 @ 3.30 GHz, 16.0 GB, 64bit win7
Inventor 2013 and Vault Basic 2013
61 REPLIES 61
Message 61 of 62
mguman
in reply to: MjDeck
Hi Mike,
Could you explain this code to me? I have created a rule where Inventor creates a PDF from the IDW upon save (I assume this is a common rule). But I want to use a keybind instead of having it make a PDF upon saving the file.
Edit:
I found a different solution to my answer. I simply imported my iLogic rule in the 'Keyboard' tab in the 'Customize' environment under 'Tools'. Assigned a keybind to it and it did the job as expected!
Message 62 of 62
MjDeck
in reply to: mguman
Hi @mguman , glad you found it. That's the best way to do it in Inventor 2023 and later. It was not available before Inventor 2023.
Mike Deck
Software Developer
Autodesk, Inc.
