Inventor General Discussion
mcgyvr
Message 1 of 13 (2,620 Views)
ilogic form dropdown?
2620 Views, 12 Replies
08-01-2012 06:06 AM
Can you have dropdowns in an ilogic FORM?
For example I want to setup 5 choices for a custom iproperty. Then when I run the form I can pick from those 5 choices only?
Down with IDW/DWG files..... Long live 3D PMI... Hurry it up already..
2015 Product Design Suite Ultimate
Windows 7 64 bit
Core i7 4820k processor (OC'd to 4.4Ghz), Nvidia GTX 770, 16G RAM
Mark_Flayler
Message 2 of 13 (2,613 Views)
Re: ilogic form dropdown?
08-01-2012 06:17 AM in reply to: mcgyvr
The way I have done it in the past is with a Custom Parameter that is Exported to be a Custom iProperty.  I use the Multi-value list from the parameter to drive the value of the Custom iProperty
Mark Flayler Application Engineer - Manufacturing Solutions Division
IMAGINiT's Manufacturing Solutions Blog:
http://blogs.rand.com/manufacturing/
*Pro
jletcher
Message 3 of 13 (2,610 Views)
08-01-2012 06:23 AM in reply to: mcgyvr
Yep you sure can Here is my form I am working on now.
James Letcher
2012 Factory Design Suite ( will not load 2013)
What happen to my Inventor :-(
Valued Mentor
rhasell
Message 4 of 13 (2,596 Views)
08-01-2012 04:23 PM in reply to: jletcher
Hi
How did make columns in your form?
Reg
Autodesk PDS Ultimate 2015 Update 1 Build 159
Intel Core i7 (950@3.07GHz)/Win7x64 (Home) - 12GB Ram
Nvidia GeForce GTX 560 Ti
Please Give Kudo's / accept as a solution if it fixes your problem.
Inv_kaos
Message 5 of 13 (2,585 Views)
08-01-2012 09:47 PM in reply to: Mark_Flayler
Mark, how do you export a multi-value text parameter?
Please mark as "Accept as Solution" if it answers your question or "Kudos" if you found it useful.
Stew, AICP
Inventor Professional 2013, Autodesk Simulation Multiphysics 2013
Windows 7 x64 Core i7 32GB Ram FX2000
Mark_Flayler
Message 6 of 13 (2,574 Views)
08-02-2012 03:39 AM in reply to: mcgyvr
Actually I misspoke, I use an ilogic rule to copy the value of the MultiValue parameter to the value of the custom iproperty.  There is no export on the MultiValue parameters.
Inv_kaos
Message 7 of 13 (2,572 Views)
08-02-2012 03:48 AM in reply to: Mark_Flayler
Would you mind sharing this code?
Stew, AICP
Curtis_Waguespack
Message 8 of 13 (2,562 Views)
08-02-2012 05:01 AM in reply to: mcgyvr
Hi everyone,
You can use MultiValue.SetList to add values and convert a parameter to a multi-value parameter.
Here's a quick example.
There is a sketch dimension / parameter called Length.
There is a rule with this line of code.
MultiValue.SetList("Length", 100, 150, 200, 250)
There is a form set up like this:
Attached is the example file (Inventor 2013)
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
Curtis_Waguespack
Message 9 of 13 (2,552 Views)
08-02-2012 05:52 AM in reply to: mcgyvr
Hi mcgyvr,
You could also add a few lines to expose (export) the parameter value as a property. So using the previous example you set the Length using a form, and this code sets the list and ensures the parameter is exported as a custom iProperty.
'set list of values
Dim oLength As Parameter
oLength = Parameter.Param("Length")
oLength.ExposedAsProperty = True
But if you need the parameter value to be written to a custom iProperty that is not the same name as the parameter you could use something like this. In this example a custom iProperty called L1 is created or reused, depending if it exists. And the Length parameter value is written to it:
'set list of values
Dim propertyName1 As String = "L1"
'define custom property collection
oCustomPropertySet = ThisDoc.Document.PropertySets.Item("Inventor User Defined Properties")
Try
'set property value
oProp = oCustomPropertySet.Item(propertyName1)
Catch
' Assume error means not found so create it
oCustomPropertySet.Add("", propertyName1)
End Try
'set custom property value
iProperties.Value("Custom", "L1") = Length
I hope this helps.
Curtis
mcgyvr
Message 10 of 13 (2,546 Views)
08-02-2012 06:22 AM in reply to: Curtis_Waguespack
iproperty NOT parameter
I just want a form with a drop down to fill in the value of a custom iproperty.
Currently I'm doing it with an "Input Box" rule which is fine but not as pretty as I could make a form.
Seems totally silly to me this isn't build into ilogic forms already..
It should be as simple as this.. See attached
Windows 7 64 bit
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
