I would like to have a rule that will add specific user parameters to a part file. These parameters need to be formatted so the width, depth and thickness will control the description of the part.
IE:
Width=4
Depth=2
Thickness=3/16
DESCRIPTION = TS <Width>X<Depth>X<Thickness>
I would like to format each parameter so that the:
Format=Fractional
Precision=1/16
Unit string=False
This is what I have so far:
oMyParameter=ThisApplication.ActiveDocument.ComponentDefinition.Parameters.UserParameters
oParameter=oMyParameter.AddByExpression("Width", "TOP_RAIL_WIDTH", UnitsTypeEnum.kInchLengthUnits)
oParameter.ExposedAsProperty=True
oParameter.Units="in"
oParameter=oMyParameter.AddByExpression("Depth", "TOP_RAIL_DEPTH", UnitsTypeEnum.kInchLengthUnits)
oParameter=oMyParameter.AddByExpression("Thickness", "TOP_RAIL_THICKNESS", UnitsTypeEnum.kInchLengthUnits)
The TOP_RAIL parameters are from a linked file.
Brian
Solved by Curtis_Waguespack. Go to Solution.
just put a check in the export box in the parameters. for the format after you put a check mark in the export box if you go over to the equation right click you wil have new options. One is custom property format in there you can change the output.....
Hi brian
Here is some iLogic code and an example file that will format parameters and add them to the Description iProperty.
I hope this helps.
Curtis
Dim oWidth, oDepth, oThickness As Parameter Dim oFormat As CustomPropertyFormat oWidth = Parameter.Param("Width") oWidth.ExposedAsProperty = True oFormat=oWidth.CustomPropertyFormat oFormat.PropertyType=Inventor.CustomPropertyTypeEnum.kTextPropertyType oFormat.Precision=Inventor.CustomPropertyPrecisionEnum.kSixteenthsFractionalLengthPrecision oFormat.Units="in" oFormat.ShowUnitsString=False oDepth = Parameter.Param("Depth") oDepth.ExposedAsProperty = True oFormat=oDepth.CustomPropertyFormat oFormat.PropertyType=Inventor.CustomPropertyTypeEnum.kTextPropertyType oFormat.Precision=Inventor.CustomPropertyPrecisionEnum.kSixteenthsFractionalLengthPrecision oFormat.Units="in" oFormat.ShowUnitsString=False oThickness = Parameter.Param("Thickness") oThickness.ExposedAsProperty = True oFormat=oThickness.CustomPropertyFormat oFormat.PropertyType=Inventor.CustomPropertyTypeEnum.kTextPropertyType oFormat.Precision=Inventor.CustomPropertyPrecisionEnum.kSixteenthsFractionalLengthPrecision oFormat.Units="in" oFormat.ShowUnitsString=False iProperties.Value("Project", "Description") = "= TS <Width> x <Depth> x <Thickness>"
Hi brian,
I'm glad to hear that worked.
I noticed that I left those first two lines of the code in. They're not really needed, and don't really do anything as written because those things get defined later in the code. They were just vestiges of my first attempt that I forgot to remove once I went a different way. I just thought I'd mention it in case it confuses someone who happens upon this in the future.
I hope this helps.
Curtis
so, this works just as well:
sir can anyone help me to update the thickness of a sheet metal, through custom properties in BOM(Assembly level)
if i create opposite hand of a part the thickness will not getting updated please help me out update through custom properties, i want like if i update the custom properties thickness then automatically it has to get updated in parameters.
thanks and regards
Manjunatha
sir, can you help me create co to remove All Custom property?
i want to clearup all custom properties and add new one.
Thanks and regard
Create the opposite hand using derived component. Derive a mirror part and bring the parameters of the original. This way both thicknesses will get updated.
it's possible to add a allow customvalues in the end of multivalue list???
oInsulationType=oUserParams.AddByValue("CHANTS", "AUCUN", kTextUnits)
MultiValue.SetList("CHANTS", "AUCUN", "1C", "1L", "1L-1C", "1L-2C", "2L", "2L-1C", "2L-2C")
Thanks for your help!
Hi Curtis,
Sorry to be a bother but my Inventor doesn't like that code. I put the rule in and then try to OK it but it comes up with an error. I've attached a screenshot of the error.
If it's not too much hassle could you tell me what the problem may be? All I did was copy and paste your code.
I have sorted it! It just took some logical effort and deciphering what the code means at each stage.
What exactly do you need? Mine is just a metric version of what Curtis has already posted earlier.
I too am trying to use iLogic to create a multivalue parameter and also make it allow custom values. So far I am stumped.
