Inventor Forum
.iam files currupt
5 REPLIES 5
avanboekel11
377 Views, 5 Replies
.iam files currupt
Okay, so I created a design in Inventor 2012 student edition on Windows 7. When I switched to 2013 on Windows 8 release preview, all of my assembly files are messed up. Everything is moved around, and not where it's supposed to be. However, all of the constraints are correct, and when I render it, it looks fine.
Any solutions are greatly appreciated.
5 REPLIES 5
Cadmanto
in reply to: avanboekel11
Welcome to the forum.
Did you try rebuilding the assembly?
Can you post the assembly here?
Best Regards,
Scott McFadden
(Colossians 3:23-25)
avanboekel11
in reply to: Cadmanto
The assembly is updated. I sent the assembly and parts to my friend who has Inventor 2012 on Windows 7. It was fine. Here is an example of what it looks like. However, at different angles and zooms, different parts move.
avanboekel11
and what its supposed to look like (for the most part)
Cadmanto
I am thinking that there is an issue with the assembly being created in the student edition.
As an experiment, try fixing it in the regular Inventor 2012 and see if it sticks.
This wouldn't be the first time I have seen an issue between a student edition and the
full blown edition.  Remember al of the commands and to some degree how they work are not the same between the two.
Best Regards,
Scott McFadden
avanboekel11
It wont open in 2012. It was modified, and saved in 2013, and it's not backwards compatable.
