Inventor Forum
iProps Wizard V2.0?
16 REPLIES 16
Message 1 of 17
263 Views, 16 Replies
iProps Wizard V2.0?
I am taking suggestion for improvements to the iPropsWizard.
Among those I have gotten so far that I think I can pull off are:
Allow the "Keep Part Color" to be defaulted to on or off (via the setup
screen)
Have a calendar control pull down on those fields that are dates
Allow some of the text fields to be list boxes that are predefined by the
setup screen
Password protect the setup screen (to keep those pesky users out of the
setup)
Anything else? I'm just starting to look at the new version. Not sure when
I will actually get around to it all.
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
www.sdotson.com/faq.html
16 REPLIES 16
Message 2 of 17
Probably not possible, but, could you make the comments property act the
same as it does in the IV properties GUI? (multi-line)
Cory McConnell
BJ pipeline Inspection
Message 3 of 17
Possibly.
Sean Dotson, PE
"Cory McConnell" wrote in message
news:50E1F7BF86DACE422D49D0D25A92FE20@in.WebX.maYIadrTaRb...
> Cory McConnell
Message 4 of 17
> setup)
What's about a switch in the registry
to enable/disable the setup command
in the pulldown menu?
> setup screen
Please, don't forget a list box for the
design status.
Michael Puschner
www.scholle.de
"Sean Dotson" schrieb im Newsbeitrag
news:8503DAAED0EE7D2197ADD990C8127C0B@in.WebX.maYIadrTaRb...
> screen)
> setup screen
> setup)
when
> Sean Dotson, PE
Message 5 of 17
If the switch was in the registry you'd have to manually edit the registry
to turn it back on. 😞
Sean Dotson, PE
"Michael Puschner" wrote in message
news:60062191383BE5BB2185DCA329BAFFCE@in.WebX.maYIadrTaRb...
> > setup)
> > setup screen
> design status.
> Michael Puschner
> www.scholle.de
> > screen)
the
> > setup screen
> > setup)
> when
> > Sean Dotson, PE
Message 6 of 17
Kind of admin and user setup I thought.
You could use *.reg files there for.
BTW, what is a good way to copy the
settings from one user/pc to another?
Also using *.reg files here.
Michael Puschner
www.scholle.de
news:1381938A0BEEE9536E8E8B52AA3F6929@in.WebX.maYIadrTaRb...
> Sean Dotson, PE
Message 7 of 17
Use the export button on the setup screen. It will save out a reg file.
Then take this to another PC, double click and it will have the same
settings as the first. (iPropWiz has to be installed of course)
Sean Dotson, PE
news:9C6A5471B0049948A73A9E68AD31FE48@in.WebX.maYIadrTaRb...
> Michael Puschner
> www.scholle.de
registry
> > Sean Dotson, PE
Message 8 of 17
This is probably for version 8 but...
(I haven't used V1.0, but from the description on your web site it appears
to work on one part at a time.)
How about the ability to set property values of multiple parts at the same
time, say 10 parts that have the same material or vendor? I like to enter
BOM info such description, vendor, and material as part properties- -but it
takes gobs of clicking and typing to accomplish it. DA shows you this info
in a nice table format, but you have to right click every single part(if I
remember right.) I don't do much DA now that I'm using semi-isolated
project files.
Is there some other way I haven't discovered to do this?
Mark Case, P.E.
http://w3.gorge.net/casecad
"Sean Dotson" wrote in message
> screen)
> setup screen
> setup)
when
> Sean Dotson, PE
Message 9 of 17
the Excel properties program on my site allows you to use Excel to copy
paste into multiple files and then save it.
Kent Keller
http://www.MyMcad.com/KWiK/Mcad.htm
Assistant Moderator
Autodesk Discussion Forum Moderator Program
"Mark Case, P.E." wrote in message
> Mark Case, P.E.
Message 10 of 17
That's what I meant ...
You use export function on the "admin" PC but
on an "user" PC you don't need the setup screen,
you just use the exported *.reg file with the settings.
To make the "user" PC an "admin" PC you can
use another *.reg file as a "hidden" switch.
Michael Puschner
www.scholle.de
news:9A6B6695AAAFC89C559172D1A457892F@in.WebX.maYIadrTaRb...
> Sean Dotson, PE
Message 11 of 17
Gotcha! Good idea. Could be a setting in the install maybe?
Sean Dotson, PE
news:989DB012643269844820EFF7327F1051@in.WebX.maYIadrTaRb...
> Michael Puschner
> www.scholle.de
> > Sean Dotson, PE
Message 12 of 17
Perfect!
I'm looking forward to do the German translation for V 2.0.
Michael Puschner
www.scholle.de
news:DEA72C8A26F0CFA75AACC70A73A6D3E9@in.WebX.maYIadrTaRb...
> Sean Dotson, PE
Message 13 of 17
Yeah, about that... what a PITA that was.
I hate to say it but from now on, I think translation to foreign languages
are going to be a paid feature. While you all were nice enough to help
translate the help files it took a LOT more code than I expected to handle
this feature.
We'll see...
Sean Dotson, PE
news:78F042982FBD0677B2F8522016A5B25E@in.WebX.maYIadrTaRb...
> Perfect!
> Michael Puschner
> www.scholle.de
> > Sean Dotson, PE
Message 14 of 17
Thanks Kent I'll try it..
Mark
Message 15 of 17
Kent,  It looks like this approach has a lot
of potential. Thanks for making it available!
It was able to change about five parts in the assy
then I got the error in the attached JPG. Any ideas?
Thanks!
 Mark
Kent I'll try it..
Mark
Message 16 of 17
Not sure if I have seen that error before or not. Are any of the files Library or is it a
Semi Isolated project?
Kent
Assistant Moderator
news:882A88350CCF87A4868FD4F69C91C2CB@in.WebX.maYIadrTaRb...
> Kent, It looks like this approach has a lot of potential. Thanks for making it
available!
> It was able to change about five parts in the assy then I got the error in the attached
JPG. Any ideas?
> Thanks!
> Mark
> "markcase" wrote in message news:f184d0e.12@WebX.maYIadrTaRb...
> Mark
Message 17 of 17
It is semi-isolated. I checked the assy(tree) out and then pointed the
spreadsheet to my workspace. It works fine then. Thanks for the tip! This
will make BOMs much, much easier.
Mark
"Kent Keller" wrote in message
news:DFF0C6F200CD82006EE698D03D39E761@in.WebX.maYIadrTaRb...
Library or is it a
> Kent
> Assistant Moderator
