This is probably for version 8 but...
(I haven't used V1.0, but from the description on your web site it appears
to work on one part at a time.)
How about the ability to set property values of multiple parts at the same
time, say 10 parts that have the same material or vendor? I like to enter
BOM info such description, vendor, and material as part properties- -but it
takes gobs of clicking and typing to accomplish it. DA shows you this info
in a nice table format, but you have to right click every single part(if I
remember right.) I don't do much DA now that I'm using semi-isolated
project files.
Is there some other way I haven't discovered to do this?
Mark Case, P.E.
http://w3.gorge.net/casecad
"Sean Dotson" wrote in message
news:8503DAAED0EE7D2197ADD990C8127C0B@in.WebX.maYIadrTaRb...
> I am taking suggestion for improvements to the iPropsWizard.
> Among those I have gotten so far that I think I can pull off are:
> Allow the "Keep Part Color" to be defaulted to on or off (via the setup
> screen)
> Have a calendar control pull down on those fields that are dates
> Allow some of the text fields to be list boxes that are predefined by the
> setup screen
> Password protect the setup screen (to keep those pesky users out of the
> setup)
> Anything else? I'm just starting to look at the new version. Not sure
when
> I will actually get around to it all.
> Sean Dotson, PE
> http://www.sdotson.com
> Check the Inventor FAQ for most common questions
> www.sdotson.com/faq.html
