Hi
Could you mail me a part where you get the wrong SM extents, then I'll look
at it and check my code to find the problem.
Regards
Patrick
mailto:pdsa@get2net.dk
"gcooper" wrote in message
news:E96899602A9D908E774E375642732B70@in.WebX.maYIadrTaRb...
> First let me thank Patrick for this great tool, it has been serving me
well.
> Now the problem, I am trying to use the sheetmetal extents for cut size
for
> sheets that have no bends. First I get an error message when I flatten the
> already flat flat. "Create Flat Pattern Window: problems encountered while
> executing this command....warning occurred during update....No bending
zone
> found" OK, I understand, there aren't any bends. It still makes a flat
after
> I accept the warning. Now if I check the extents I get an expected result,
> in this case my template is 12x12. Now it gets strange, when I check
> SM_Extents in my custom properties I get 59.918x27.732. Where did that
come
> from? I'm also using iProp Wizard if that could have anything to do with
it?
> Anybody else using cut sheets of plywood or flooring? How are you
generating
> cutlists and BOMs? What's the best practice for this? Maybe I'm going down
> the wrong road?
> TIA
> gcooper
