Inventor Forum
iProperties variables in iPart tables?
1 REPLY 1
RobertWK
456 Views, 1 Reply
Currently the way I am using iParts is somewhat not the explicit intent; often I have parts which look more or less exactly the same externally (and sometimes internally) but have different descriptions/properties/descriptions so I have been building iParts to have tables that contain different iProperty part numbers with different iProperty descriptions, with the same geometery. This way I have the potential to use different sub-part numbers without having to create a new .ipt each time; they already exist in the iPart table.
Is there a listing of the variables that you can use in iPart tables to populate iProperties entries? The ones I am editing are already listed in excel when I use it to edit the iPart tables.
1 REPLY 1
johnsonshiue
in reply to: RobertWK
Hi! You can edit the iPart Author table using Edit Table command (right-click on the table node in the browser -> Edit Table). Then go to Properties tab. All the configurable iProperties are listed there.
Thanks!
Software Test Engineer
