I've inserted <CREATION DATE> into the custom title blocks I normally use for drawings. It displays the date without preceding zeros (example: June 18, 2013 is displayed as "6/18/2013" instead of "06/18/2013"). How can I change this?
Solved by Cadmanto. Go to Solution.
Try changing your global settings in the control panel and see if that makes a difference.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
I have thought about this for a long time and never thought about doing this. Thank you so much for a load off my mind.
