Hello all,
Quick question regarding iParts vs iLogic...
I have recently completed a course in which I made use of a table to drive parts (nothing too complex) simply length,supression of features etc.
My tutor mentioned that i would most likely never use the method I had for the assignment in the future & that iLogic was an easier way to accomplish on the fly changes to a model.
My question is are the two interchangeable, is one more favourable for simple projects and the other better suited to more complex situations, am I better off investing my time into learning more of iLogic or do the two features compliment one another?
Just as an example of the simplicity I am currently fiddling around with, I have a 1/2 piece lego brick which I then switch to a double or triple brick with the use of the iPart feature.
Looking forward to hearing back from some of you.
Daniel
Solved by Curtis_Waguespack. Go to Solution.
You can use ilogic in iParts. I would suggest learning both. Both come in very handy in different situations.
There is usually more than one way to do anything in any program..
A "smart" student learns as much of the program as possible..
IF you have some programming knowledge then ilogic is a GREAT tool.. But if you don't.. Its basically useless an then using the built in "no programming skills necessary" functionality is the way to go..
Hi LeedsLad8t6,
iParts = part configurations (or families of parts). Basically it is useful for setting up "same but different" parts. You can create custom iParts that allow you to place "on the fly" variations of your iPart, but it is more common to use iParts to create known variations of size, material, etc.
iLogic can be used to create part configurations as well, but it can also be used to automate all sorts of tasks in Inventor.For instance, maybe you want to quickly turn off all of the work features in your model:
http://inventortrenches.blogspot.com/2013/03/turn-onoff-all-workfeatures-with-ilogic.html
Maybe you want to clean up a bunch of broken assembly constraints:
http://inventortrenches.blogspot.com/2013/01/ilogic-delete-all-sick-assembly.html
Maybe you want to extrude a complex logo quickly, and need to do it often:
http://inventortrenches.blogspot.com/2012/03/ilogic-to-select-all-of-closed-profiles.html
So, iLogic allows you to automate Inventor, where as iPart allow you to configure a specific family of parts. As the others have said, these are two distinct tool sets, and knowing both will be useful going forward.
Also, I might be a bit cautious about taking the advise of the instructor who tells you "you probably won't ever use this in real life" to heart. Most likely it just means that they have not had the need to use the tool or functionally in question in real life. But it could very likely end up being a critical part of your day to day job function at some point in the future, depending upon the product, industry, or region you end up working in.
I hope this helps.
Curtis
I have been using Ipart factories for some time. They are a gret time saver. The Iproperties do not update automatically in the parent part when switching between differeent variations of the part(s). I have to go to each version part and run an I logic rule to make the Iproperties update or (rmb on iproperties/physical tab/update) (what the rule does).
Do you or any body reading this post - Know of a rule that would update all child parts mass prop that I could trigger "before save" from the parent part or something simular? Alterativly triggered from the idw to update the physical model properties in the IDW view(s).
If you do please share
IV 2013
Inside your iParts you can set your Event Trigger to “run” before save document. When you save your top level assemblies then click yes to save all. If you are on the drawing level you can click on the view and then click the update button then save all.
For example we use a simple code that takes the file name and splits it to fill out two of our custom iProperties.
'MarkNumber and Job Information iProperties.Value("Project", "Part Number") = ThisDoc.FileName(False) 'without extensionTry 'Filename Convert Part_Number = iProperties.Value("Project", "Part Number") Job_Split = Split(Part_Number, "-")(0) Mark_Split = Split(Part_Number, "-")(1) iProperties.Value("Custom", "Job" ) = "=" & Job_Split iProperties.Value("Custom", "MarkNumber") = "=" & Mark_Split Catch End Try iProperties.Value("Custom", "Mass")=Round(iProperties.Mass) iProperties.Value("Custom", "Masskg")=Round(iProperties.Mass*0.45359237)
I hope this Helps
