Inventor General Discussion
Member
russellafranklin76
Message 1 of 7 (98 Views)
iPart help required
98 Views, 6 Replies
05-03-2014 07:04 AM
Hi All
I have built an actuator which will be used with a number of different stroke values. In the iassembly I have a constraint which needs to be driven by the value of the stroke. How can I pull in the stroke value when I change actuator?
Distinguished Mentor
mdavis22569
Message 2 of 7 (80 Views)
Re: iPart help required
05-03-2014 02:00 PM in reply to: russellafranklin76
Can you attach the assembly ... it looks like there is an issue ...look at the icon next to the assembly ..
Michael Davis
Charlotte, NC
Member
russellafranklin76
Message 3 of 7 (77 Views)
05-03-2014 03:01 PM in reply to: mdavis22569
Hi Michael
Yeah, I did notice this. I have attached the assembly for you to have a look at.
mdavis22569
Message 4 of 7 (73 Views)
05-03-2014 03:13 PM in reply to: russellafranklin76
You might want to consider putting them in a linked excel spreadsheet .. a formula to make easily would be ... X distance +Stroke Or you can make an Iassembly made of of various assemblies based on the stroke desired. and my final suggestion: Ilogic (I'm not the best at this so I'll leave that to someone else to help on)
Michael Davis
Charlotte, NC
mdavis22569
Message 5 of 7 (72 Views)
05-03-2014 03:13 PM in reply to: mdavis22569
Oh and the fix is just the thread needs to be fixed, as it doesn't match the diameter 185 vs 186
Michael Davis
Charlotte, NC
Member
russellafranklin76
Message 6 of 7 (51 Views)
05-04-2014 06:26 AM in reply to: mdavis22569
That's great, I'll try the spreadsheet method.
Thanks for your help
Employee
johnsonshiue
Message 7 of 7 (40 Views)
05-04-2014 08:11 PM in reply to: russellafranklin76
Hi! I may not have understood the design intent correctly. But, I think you might be better off making the constraint a Limit Constraint so the piston can move freely within a range. Do you have to specify the exact position? Thanks!
Principal SQA Engineer, Inventor
Mechanical Design
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
