Hello All,
At the moment we have an iLogic code in our drawing template that asks for increase revision number when pressing the save button and then autom. makes an PDF file with the REV no. in the file name etc. This is nothing specials.
In the past (and still) our company works with Revision Letters (A, B, C). In exisiting production molds and dies a number is engraved with the related revision letter.
You see the question ... Does anyone know how to change (or make) an iLogic rule to achieve this for revision Letters?
With numbers it's easier, all you do is "Revision no. +1 ".
Looking forward to your answers.
Try this (iLogic) code. Hopefully you can see that the variable "RevCode" can be incremented (RevCode = RevCode + 1) to get your revision bumps.
RevCode = 65 'This is the ASCII character code for a capital "A"
RevLetter = Chr(RevCode) 'This retrieves the character from the code number
MessageBox.Show("Revision: " & RevLetter, "Code: " & RevCode)
If you are embossing this text, then create "RevLetter" as a text user parameter, then you can emboss using the RevLetter parameter. Your code would become:
RevCode = Asc(RevLetter) 'This gets the ASCII character code for the letter contained in the RevLetter user parameter.
...and now you can do RevCode = RevCode + 1
RevLetter = Chr(RevCode) 'This puts the updated letter back into the RevLetter parameter so the emboss will update.
Actually, this is a more tidy solution:
Rule:
Rev = Chr(Asc(Rev)+1)
iLogicVb.UpdateWhenDone = True
(You need the last line, otherwise the part won't update automatically)
Sample part attached if you want to play. (2014 format)
The revision letter in the part works correct thank you, I understand it.
But now I want when I run the code below in stead of Rev numbers Rev Letters.
At the moment I use this code for auto PDF/DXF and increment of Rev nr when you want it.
I puzzled a bit but can't get it working.
noView1=True If (Not ThisDoc.Path="") Then noView1=False On Error Goto geenView oModelname= (IO.Path.GetFileName(ThisDrawing.Sheet("sheet:1").View("VIEW1").ModelDocument.FullFileName)) noView1=True If Right(oModelname,3)="ipn" Then MessageBox.Show("Let op! Er is geen PDF/dxf gemaakt. VIEW1 mag geen ipn zijn", "Error" ,MessageBoxButtons.OK,MessageBoxIcon.Error) Exit Sub End If oStocknummer = iProperties.Value(oModelname, "Project", "Stock Number") oPartname= iProperties.Value(oModelname, "Project", "Part Number") oProjectnummer = iProperties.Value(oModelname, "Project", "Project") oPath = ThisDoc.Path oPDFAddIn = ThisApplication.ApplicationAddIns.ItemById _ ("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}") oDocument = ThisApplication.ActiveDocument oContext = ThisApplication.TransientObjects.CreateTranslationContext oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism oOptions = ThisApplication.TransientObjects.CreateNameValueMap oDataMedium = ThisApplication.TransientObjects.CreateDataMedium oRevisieoud = iProperties.Value("Project", "Revision Number") dxfgemaakt = False PDFgemaakt = False oFileName = ThisDoc.FileName(False) 'revisienummer van model 0 stellen If iProperties.Value(oModelname, "Project", "Revision Number") = "" Then iProperties.Value(oModelname, "Project", "Revision Number") = 0 End If RuleParametersOutput() oRevNum = iProperties.Value(oModelname,"Project", "Revision Number") If iProperties.Value("Project", "Revision Number")<iProperties.Value(oModelname, "Project", "Revision Number") Then question = MessageBox.Show("Revisie van Part/assembly is al opgehoogt. Revisie nogmaals ophogen?", "Revisie",MessageBoxButtons.YesNo,MessageBoxIcon.Question, MessageBoxDefaultButton.Button2) If question = vbYes Then oRevNum = oRevNum + 1 iProperties.Value("Project", "Revision Number") = oRevNum iProperties.Value(oModelname, "Project", "Revision Number")= oRevNum End If Else 'Revisie ophogen? question = MessageBox.Show("Revisie ophogen?", "Revisie",MessageBoxButtons.YesNo,MessageBoxIcon.Question, MessageBoxDefaultButton.Button2) If question = vbYes Then oRevNum = oRevNum + 1 iProperties.Value("Project", "Revision Number") = oRevNum iProperties.Value(oModelname, "Project", "Revision Number")= oRevNum End If End If question = MessageBox.Show("PDF en/of dxf maken?", "PDF/dxf",MessageBoxButtons.YesNo,MessageBoxIcon.Question) If question = vbNo Then Exit Sub End If iProperties.Value("Project", "Revision Number") = iProperties.Value(oModelname, "Project", "Revision Number") InventorVb.DocumentUpdate() 'PDF instellingen wijzigen If oPDFAddIn.HasSaveCopyAsOptions(oDataMedium, oContext, oOptions) Then oOptions.Value("All_Color_AS_Black") = 0 oOptions.Value("Remove_Line_Weights") = 0 oOptions.Value("Vector_Resolution") = 400 oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets 'oOptions.Value("Custom_Begin_Sheet") = 2 'oOptions.Value("Custom_End_Sheet") = 4 End If 'get PDF target folder path oFolder = oPath & "/pdf" 'Check for the PDF folder and create it if it does not exist If Not System.IO.Directory.Exists(oFolder) Then System.IO.Directory.CreateDirectory(oFolder) End If oNewfilename = oFolder & "\" & oFileName & " Rev" & oRevNum & ".pdf" If oRevNum = 0 Then oNewfilename = oFolder & "\" & oFileName & ".pdf" End If 'Checken of PDF al bestaat If My.Computer.FileSystem.FileExists(oNewfilename) Then question = MessageBox.Show("PDF bestaat al, overschrijven?", "iLogic Question",MessageBoxButtons.YesNo,MessageBoxIcon.Question) If question = vbNo Then MessageBox.Show("Let op! Er is geen PDF gemaakt.", "Error" ,MessageBoxButtons.OK,MessageBoxIcon.Error) Goto dxfMaken End If End If 'Oude revisie verplaatsen If (Not oRevisieoud="") And oRevisieoud <> oRevNum And My.Computer.FileSystem.FileExists(oFolder & "\" & oFileName & " Rev" & (oRevisieoud) & ".pdf") Then If Not System.IO.Directory.Exists(oFolder & "\revisies") Then System.IO.Directory.CreateDirectory(oFolder & "\revisies") End If On Error Resume Next My.Computer.FileSystem.MoveFile(oFolder & "\" & oFileName & " Rev" & (oRevisieoud) & ".pdf",oFolder & "\revisies" & "\" & oFileName & " Rev" & (oRevisieoud) & ".pdf") End If If (Not oRevisieoud="") And oRevisieoud <> oRevNum And My.Computer.FileSystem.FileExists(oFolder & "\" & oFileName & ".pdf") Then If Not System.IO.Directory.Exists(oFolder & "\revisies") Then System.IO.Directory.CreateDirectory(oFolder & "\revisies") End If On Error Resume Next My.Computer.FileSystem.MoveFile(oFolder & "\" & oFileName & ".pdf",oFolder & "\revisies" & "\" & oFileName & ".pdf") End If 'Set the PDF target file name oDataMedium.FileName = oNewfilename PDFerror=False On Error Goto handlePDFLock 'Publish document oPDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium) PDFgemaakt = True PDFerror = True handlePDFLock: If PDFerror = False Then MessageBox.Show("PDF kon niet worden overschreven. PDF is waarschijnlijk geopend.", "Error", MessageBoxButtons.OK,MessageBoxIcon.Error) End If dxfMaken: curDoc = ThisDrawing.Sheet("sheet:1").View("VIEW1").ModelDocument If curDoc.DocumentType = kPartDocumentObject And curDoc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then oDoc = ThisApplication.Documents.Open(curDoc.FullFileName, True) oCompDef = oDoc.ComponentDefinition If oCompDef.HasFlatPattern = False Then oCompDef.Unfold Else oCompDef.FlatPattern.Edit End If 'get dxf target folder path oFolder = oPath & "\dxf" 'Check for the dxf folder and create it if it does not exist If Not System.IO.Directory.Exists(oFolder) Then System.IO.Directory.CreateDirectory(oFolder) End If oNewfilename = oFolder & "\" & oFileName & " Rev" & oRevNum & ".dxf" If oRevNum = 0 Then oNewfilename = oFolder & "\" & oFileName & ".dxf" End If 'Checken of dxf al bestaat If My.Computer.FileSystem.FileExists(oNewfilename) Then question = MessageBox.Show("dxf bestaat al, overschrijven?", "iLogic Question",MessageBoxButtons.YesNo,MessageBoxIcon.Question) If question = vbNo Then MessageBox.Show("Let op! Er is geen dxf gemaakt.", "Error" ,MessageBoxButtons.OK,MessageBoxIcon.Error) Goto oEinde End If End If 'Oude revisie verplaatsen If (Not oRevisieoud="") And oRevisieoud <> oRevNum And My.Computer.FileSystem.FileExists(oFolder & "\" & oFileName & " Rev" & (oRevisieoud) & ".dxf") Then If Not System.IO.Directory.Exists(oFolder & "\revisies") Then System.IO.Directory.CreateDirectory(oFolder & "\revisies") End If On Error Resume Next My.Computer.FileSystem.MoveFile(oFolder & "\" & oFileName & " Rev" & (oRevisieoud) & ".dxf",oFolder & "\revisies" & "\" & oFileName & " Rev" & (oRevisieoud) & ".dxf") End If If (Not oRevisieoud="") And oRevisieoud <> oRevNum And My.Computer.FileSystem.FileExists(oFolder & "\" & oFileName & ".dxf") Then If Not System.IO.Directory.Exists(oFolder & "\revisies") Then System.IO.Directory.CreateDirectory(oFolder & "\revisies") End If On Error Resume Next My.Computer.FileSystem.MoveFile(oFolder & "\" & oFileName & ".dxf",oFolder & "\revisies" & "\" & oFileName & ".dxf") End If 'Set the dxf target file name sOut = "FLAT PATTERN DXF?AcadVersion=R12&OuterProfileLayer=Burn&InteriorProfilesLayer=Burn&InvisibleLayers=IV_TOOL_CENTER_DOWN;IV_TOOL_CENTER;IV_ARC_CENTERS;IV_TANGENT;IV_BEND;IV_BEND_DOWN;IV_FEATURE_PROFILES;IV_FEATURE_PROFILES_DOWN;IV_ALTREP_FRONT;IV_ALTREP_BACK;IV_UNCONSUMEND_SKETCHES;IV_ROLL_TANGENT;IV_ROLL&SplineTolerance Double 0.01" dxferror=False On Error Goto handledxfLock 'Publish document. oCompDef.DataIO.WriteDataToFile( sOut, oNewfilename) dxfgemaakt = True dxferror = True handledxfLock: If dxferror = False Then MessageBox.Show("dxf kon niet worden overschreven. dxf is waarschijnlijk geopend.", "Error", MessageBoxButtons.OK,MessageBoxIcon.Error) End If oEinde: ThisApplication.ActiveDocument.Close End If End If If dxfgemaakt = True And PDFgemaakt=True Then MessageBox.Show("PDF en dxf zijn gemaakt.", "Finish", MessageBoxButtons.OK) End If If dxfgemaakt = True And PDFgemaakt=False Then MessageBox.Show("dxf gemaakt.", "Finish", MessageBoxButtons.OK) End If If dxfgemaakt = False And PDFgemaakt=True Then MessageBox.Show("PDF gemaakt.", "Finish", MessageBoxButtons.OK) End If geenView: If noView1 = False Then MessageBox.Show("Let op! Er is geen PDF/dxf gemaakt. Geen 'VIEW1' gevonden. Geef één van de aanzichten de naam 'VIEW1'", "Error", MessageBoxButtons.OK,MessageBoxIcon.Error) End If Exit Sub
