Inventor Forum
iLogic Save file crashes
7 REPLIES 7
Message 1 of 8
2359 Views, 7 Replies
I seem to have my task accomplished, but Inventor crahes on me after it is done.
Here is how my iLogic works.
' Deleting the suppressed parts from the assembly
Dim compDef as AssemblyComponentDefinition
compDef = ThisDoc.ComponentDefinition
Dim compOcc as ComponentDefinition
For Each compOcc in compDef
   If compOcc.suppressed = true then
        compOcc.Delete
   End if
Next
' Saving a copy of the assembly components
Dim refDocs as DocumentsEnumerator=ThisDoc.Document.AllReferencedDocuments
Dim compCount As Integer = refDocs.Count
For j = 1 to compCount
    refDocs.item(j).SaveAs( "C:\MyPath\Parts\Part" & j & ".ipt", False)
Next
' Saving a copy of the assembly document
ThisDoc.Document.SaveAs( "C:\MyPath\Assembly\Pallets.iam", False)
Now as soon as the last line is executed, Inventor crashes.
But when I go to the save file part (C:\MyPath), both the parts and assembly files are saved and if I open it, they work just fine.
I just can't get inventor to stop crashing.
All help is appreciated. Thanks
Wajih
Tags (3)
7 REPLIES 7
Message 2 of 8
mrattray
Does it crash if you change the saveas argument for save copy as to true?
It works on my test part (without the preceding code).
Does it crash if you comment out the loop that saves off copies of the parts?
Mike (not Matt) Rattray
Message 3 of 8
in reply to: mrattray
Hi Mike,
I have tried several attempts.
Yes, if I set it true for the parts;
In the newly saved assembly, the assembly is composed of the the orginal parts rather than the newly saved parts.
If I set it true for the Assembly document it saves is and it still crashes, thus I cannot tell if opens up the new assembly or sticks with the old one.
Thats the strange part, I have the same code (Copied) on anther assembly, but it does not have the part where it deletes the suppressed parts. and no problems with that what so ever.
Yes, again. In fact I put up msgbox at each step and saving the part files seems to be working fine. It crashes right after it saves the new assembly document.
I am guessing it has some trouble opening the new file. Probably with something to do with the Level of Detail (but then again, I mightbe way off).
I'll keep playing. But thanks again for your time.
Message 4 of 8
mrattray
Can you post the files?
Message 5 of 8
I don't know what made it work, but it is a result of any one of the following;
1.    I saved the path for the folder paths for the assembly and the part files in two separate variables and refered to them in Save/SaveAs instructions
2.    I change the DisplayName of the parts through a separate loop and save the parts exaclty as their display name
i.e.
refDocs.item(j).SaveAs(folderPathforParts & refDocs.item(j).DisplayName & ".ipt", False)
then
ThisDoc.Document.SaveAs(folderPathforAssembly & "MyPallet.iam", false)
3. I cleared up my desired directory for the parts and the assembly (I ended up with a lot of clutter after several runs)
Now the rule works just fine.
Replaces old files and creates new without a glitch.
Thanks for your time.
Message 6 of 8
Yijiang.Cai
When using the code lines you provided in iLogic, the error will show. So I update the code lines and run it, works fine. Please see the updated one below. If crash is still reproducible, could you attach the dataset for further investigation?
Dim compDef As AssemblyComponentDefinition
compDef = ThisDoc.Document.ComponentDefinition
Dim compOcc As ComponentOccurrence
For Each compOcc In compDef.Occurrences
If compOcc.Suppressed = True Then
compOcc.Delete
End If
Next
For j = 1 To compCount
Next
River Cai
Inventor Quality Assurance Team
Autodesk, Inc.
Email: River-Yijiang.Cai@autodesk.com
Message 7 of 8
in reply to: Yijiang.Cai
Hey River,
This is a totally different file (i.e. Not the same file I originally posted about).
But
In this new assembly, I am trying to do the same thing and inventor crashes exaclty the same way.
I also tried the crashing behaviour on another computer.
I have created a .zip file for you to investigate
Methods, how to run the file;
1. In the Parameters Window, there is a User Paramter (type;True/False) named "saveCopy" set as "False", change it to "True" to execute the iLogic rule named "saveCopy2"
Or you can do this
2. In the forms window, there is a form which has the same Parameter (as mentioned in method 1), change the value to "True" to run the rule (same rule|| method 1)
On how to crash:
if you use method 2, Inventor would not crash,
if you use method 1, Inventor crashes
My inferences:
1. In the newly created assembly, the names for the various occurrences (components) change, therefore the rules which address the assembly components still refer to the old names and might be cuasing the crash when Inventor tries to open up the new assemby file.
But I suppressed the rules which are intended to be run before the "saveCopy2" but it still crashes
2. if you use method 2, the names for the sub-assemblies in the Browser window do not appear to have changed. But they actually have changed. You can verify that when you close the assembly and open the same back again. Then you see the new names in the Browser window
Let me know what I am doing wrong.
Thanking you
Wajih
Message 8 of 8
Yijiang.Cai
Many thanks to provide the details and dataset to me for further investigation, and I could reproduce the crash, which has been logged as 1472915 in our tracking system. However one VBA is created based on the iLogic "SaveCopy2". When running the VBA, it does work fine. Please see the attached one.
River Cai
Autodesk, Inc.
