Im linking a prompted entry in a sketch symbol to a selection from the user in an array.
The code works perfectly.
The array displays the number of sheets there are in the document, the user selects the correct one & the sheet number is displayed in the prompted entry.
I need to add "SHT" before the number though in the code but I cant get it to work.
Any Ideas?
I dont jwant to add a text line into the symbol saying "sht"
Sandy
Code:
Dim oApp As Application: oApp = ThisApplication
Dim oDoc As DrawingDocument: oDoc = oApp.ActiveDocument
Dim oSheet As Sheet: oSheet = oDoc.ActiveSheet
'This uses a sketch symbol with the name "'View On' View Label"
Dim oSymDef As SketchedSymbolDefinition: oSymDef = oDoc.SketchedSymbolDefinitions.Item("'View On' View Label")
'This is the selected view
Dim oView As DrawingView: oView = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingViewFilter,"Select View To Place Symbol:")
'This takes the label items of the selected view
'And adds it To an array that will link To the prompted entry
Dim sPromptStrings(2) As String
sPromptStrings(0) = oView.Name
sPromptStrings(1) = oView.ScaleString
oDoc = ThisApplication.ActiveDocument
Dim sSheet As Sheet
'create sheet number list
Dim oSheetList As New ArrayList
i = 0
s = "-"
For Each sSheet In oDoc.Sheets
i = i +1
oSheetList.add(i)
Next
oSheetList.add(s)
'get user input
mySheet = (InputListBox("View taken form sheet number.", oSheetList, oSheetList(0), "Sheet Number Ref.", "Sheet Numbers"))
sPromptStrings(2) = mySheet
'This is the position for the sketched symbol under the selected view'
Dim oPosition As Point2d: oPosition = oView.Center
oPosition.y = oPosition.y - (oView.Height / 2 + 2.5)
'This inserts the sketched symbol and fills in the prompted entry.
Dim oSymbol As SketchedSymbol: oSymbol = oSheet.SketchedSymbols.Add(oSymDef, oPosition, , ,sPromptStrings)
Try making the following changes highlighted in red:
Dim sSheet As Sheet
i = 0
s = "-"
i = i +1
oSheetList.add("SHT " & i)
Next
oSheetList.add(s)
'get user input
sPromptStrings(2) = Right(mySheet, Len(mySheet) - 4)
Give that a try and see if it will work for you. This makes it so your input box list displays like so:
But the value stored into your array will be just the sheet number.
Cameron Whetten
Inventor 2014
Please click "Accept as Solution" if this response answers your question.
