Inventor Forum
iLogic Form Button
14 REPLIES 14
Message 1 of 15
zdhrichard
6369 Views, 14 Replies
iLogic Form Button
1. Can I add more button into iLogic Form?
2. I want to define "Button1" to run "Rule 1", "Botton 2" to run "Rule 2". How can I do it?
Rich
Autodesk Inventor Professional 2018 (64 Bit Edition)
Build: 284, Release 2018.3
Windows 7 Professional Service Pack 1
Intel(R) Xeon(R) CPU E5645
12.0 GB Memory
14 REPLIES 14
Message 2 of 15
Cadmanto
in reply to: zdhrichard
Richard,
I don't know much about iLogic, but am learning slowly.
Are you talking about a custom button on the ribbon that executes a rule?
Can post an image?
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 3 of 15
zdhrichard
in reply to: Cadmanto
Here it for example iLogic Form. There are three button which Inventor defined. I want to add more button and define their function.
Rich
12.0 GB Memory
Message 4 of 15
zdhrichard
I do not know why I cannot attached my attachment.
If you are familiar with iLogic Form, you should know what I am talk about. There are three pre-defined buttom in Inventor iLogic Form (OK, Apply and Cancel). I want add more.
Rich
12.0 GB Memory
Message 5 of 15
zdhrichard
Here is the picture which has Inventor pre-defined Button in Form.
Rich
12.0 GB Memory
Message 6 of 15
Cadmanto
Thank you for sharing that.  That is not quite what I was thinking it was.  I was thinking these were buttons on the ribbon.
Best Regards,
Scott McFadden
Message 7 of 15
mrattray
Simply flip to the rules tab in the form editor and drag the rule onto the form.
Mike (not Matt) Rattray
Message 8 of 15
zdhrichard
in reply to: mrattray
Thanks lot Mike.
It is what I want.
Could you please let me know how I can adjust the location of this button also? This button is mixed with pre-defined botton in Forms.
And coudl you please help me answer the question in fololowing link?
http://forums.autodesk.com/t5/Inventor-General/Parameters-Sequence-in-iLogic-Form/td-p/4861938
Thanks.
Rich
12.0 GB Memory
Message 9 of 15
mrattray
The form editor doesn't give you much freedom to get creative with your forms. There's no way to mix it in with the predefined buttons, sorry. If you really need to have more control over your forms, you can create one in the API. The API forms feel much more like VB.net forms, which I suspect you're familiar with and can be called using a simple VBA macro which in turn can be called using iLogic. This is something I've had to do in the past.
Message 10 of 15
danmachen1990
Hi zdhrichard, I am trying to create a unique part number generator through inventor using radio group buttons like you have in your picture here.
I am interested in the code you used to create the model part number in the text box from inputting values to the radio buttons.
Could you help?
Message 11 of 15
zdhrichard
in reply to: danmachen1990
Hello Danmachen,
For using radio group buttons, you need to know your input at first. So, when you define a user parameter, you could use let it to be multi-valve list and put your multi input in the list.
Then in Forms under iLogic Browser Tab, you could Add Form. In Form Editor, you could pull the parameter into the form which you want to make. Rest, I believe you could do it. You do not need extra code, I think.
Rich
12.0 GB Memory
Message 12 of 15
danmachen1990
Ok, So I have created radio group buttons using the form and with fx parameters and made them multi-choice.
I want to be able to take the Selections from the Radio Group buttons to piece together a part number. For example in the attached image, I would like the part number to be:
AA_EXAMPLE_PART_NAME_A
I Noticed you had something similar to this in an attached image you posted.
Ideally, I would like a macro which automatically numbers part in sequential order based on their Structure and Section (see image).
Example:
AA001A_EXAMPLE_PART_NAME
AA002A_EXAMPLE_PART_NAME2
EC001A_EXAMPLE....
ETC.
Any advice?
If I can create this sequential numbering system in the VB script, I can assign it to a variable and use it to name my file to the same as the part number.
Message 13 of 15
zdhrichard
You could seperate your P/N to a few parts (parameters). As I could see:
The first parameter could be "FIRST" multi-valve as: (AA001A, AA002A, EC001A,.......)
The second one could be "SECOND" as (PART_NAME, PART_NAME2, ......)
If you like, you could make more.
Then you could get your part number by code
PartNumber = FIRST &  "_EXAMPLE_" & SECOND
You could add this code to a rule. And let this rule to be run after finish your input. And you may or may not need to put code
iLogicVb.UpdateWhenDone = True
to let it be updated.
Rich
12.0 GB Memory
Message 14 of 15
danmachen1990
That sounds like exactly what I want.
Do you know how I can extract the AA or EC from the selection of the radio buttons on the user form?
The part number needs to be generated from the user form selection.
Thank you.
Dan
Message 15 of 15
zdhrichard
Two options could do.
1. Seperate the first two letter as a parameter.
2. If you do not want tdo so, you could use following code:
FirstTwoLetter = mid (partnumber, 1, 2)
or
FirstTwoLetter = left (partnumber, 2)
Rich
12.0 GB Memory
