Inventor General Discussion
Valued Contributor
chrisrodway
Message 1 of 3 (253 Views)
iFeature Placement
253 Views, 2 Replies
01-21-2013 03:32 AM
Im just starting to look at Ifeatures to help me design, but even though my sketch is fully constrained when I place the iFeature with multiple references i can still move it using the arrows. Any ideas how i could place them more accurately
Cheers
Chris
Design Engineer
Sheffield, UK
Cheers
Chris Rodway
Design Engineer
Sheffield, UK
Product Support
Nicolas.Bourquin
Message 2 of 3 (223 Views)
Re : iFeature Placement
01-22-2013 06:01 AM in reply to: chrisrodway
Thank you for having posted your question on the discussion group.
In fact when you want to select an ifeature and insert it you need to:
1) select the ifeature from the library to select an existing face of your part 2) place approximately the position of the ifeature 3) change (if necessary) the values of the parameters 4) open the sketch of the inserted ifeature and at this time you have the possibility to fully constrain (position) the sketch to the existing geometry.
Here are some links which could interest you:
http://wikihelp.autodesk.com/Inventor/enu/2013/Help/1310-Autodesk1310/1500-Parts1500/1580-iFeature15...
http://wikihelp.autodesk.com/Inventor/enu/2013/Help/0126-Tutorial126/0127-Inventor127/0351-iFeature3...
I hope that helps.
Please, mark any response clicking on "Accept as Solution" button if it answers your question
Nicolas Bourquin
Valued Contributor
chrisrodway
Message 3 of 3 (196 Views)
01-24-2013 03:44 AM in reply to: Nicolas.Bourquin
Hi Nicolas,
Ive found out what I was doing wrong thanks to your reply and links. I was placing my Ifeatures without
activating the sketch, this causes the iFeature to have no constraints.
Cheers for the reply
Chris Rodway
Design Engineer
Sheffield, UK
Cheers
Chris Rodway
Design Engineer
Sheffield, UK
