Hi, is there any way i can use iLogic code to set the "Instance Number" and "Offset" of an iCopy feature i have in my drawing?
Thanks!
The thing is, I've tried to work with parameters, but for some reason, the "Instance Number" field doens't allow them, altough the "Offset" field does...
And before you ask, yes, I'm sure the "BL_NR" parameter exists. 🙂
