I am trying to figure out what the best way to show 2 different subassemblies based on the same iAssembly... I would expect a "custom" option as there is from the content center. If I try and change the table for one, the other instance gets updated, and I would like it to stay the same. I understand that this would require a new "branch" in the BOM holding the different sized parts, but there must be a way to accomodate this?
I am sure that I just not approaching this the right way - any help will be appreciated.
Thanks!
Michael
Michael,
When you say trying to show two different subassemblies are you talking about in a drawing or just in general?
One with a standard part from the CC and the other a custom part? You could can control this in the factory table.
What I mean is insert them both into your subassembly then toggle their suspension within the table.
Then they would have two seperate member names to place in a drawing or the top level assembly.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
