Inventor Forum
iAssembly Pattern not updating correctly!
7 REPLIES 7
Message 1 of 8
410 Views, 7 Replies
See attached dataset.
If you change from "3 - WITH Rounds" to "6 - WITHOUT Rounds", some elements
in the pattern are not being excluded.
T. Ham
CAD Automation & Systems Administrator
CDS Engineering BV
HP xw4300 Workstation
Dual Pentium XEON 3.6 Ghz
4 GB SDRAM
NVIDIA QUADRO FX 3450/4000 SDI (Driver = 6.14.10.9185)
250 GB SEAGATE SATA Hard Disc
3Com Gigabit NIC
Windows XP Professional SP2
Autodesk Inventor Series 10 SP3a
Autodesk Inventor Suite 2008 SP1
7 REPLIES 7
Message 2 of 8
And a videoclip showing the problem...
T. Ham
CDS Engineering BV
4 GB SDRAM
3Com Gigabit NIC
Message 3 of 8
I "solved" this issue by setting the number elements of the pattern to "1"
when it is being suppressed (excluded).
But I still think that the iAssembly is not correctly updating when you
switch from one element to another...
T. Ham
CDS Engineering BV
4 GB SDRAM
3Com Gigabit NIC
Message 4 of 8
billco-mfg
I had a similar problem:
http://discussion.autodesk.com/thread.jspa?messageID=5772844
Message 5 of 8
nbradbury
I am having the same issue. Attached is a picture showing the pattern that is excluded and the pattern still showing up in the model. When I look at the BOM the excluded parts are not there and if I make a drawing the excluded parts do not show up either. Has anyone figured out what the problem is?
N-
Message 6 of 8
kpanik
I'm not sure this is the same issue, but I have an iassembly stairway modeled that acts the same way updating the iassembly.
But when placing the iassembly child in an assembly it always depicts the correct assembly.
So, what I am trying to say is that my iassemblies do not update correctly until it is placed into an assembly.
HTH
kp
btw: IV11
Message 7 of 8
Cschmidt
When did iassemblies\iparts start working?
Message 8 of 8
Teum,
I have verified the behavior on R2008. But, I am not able to reproduce it on R2009. It seems to work there.
Johnson Shiue
Inventor QA Tech Lead
