For the Kind Attn:- Mr. Curtis/JD Mather
Dear Sir,
I have completed my final part modelling, but as you know that before final machinig the part i want to get it forged from my vendor for that i want to prepare the forging drawing for him. but when i place the base view in the drawing sheet i always get the final part. please suggest how to prepare the forging drawing from the final part drawing or is there any way to make it.
Abhinay
Solved by JDMather. Go to Solution.
HI!
Did you find this reply helpful ? If so, use the Accept as Solution or Kudos - Thank you!
Dear Sir,
Thanks for your reply. But if i make the two rows 1 for forging & second for machining, but when i make the drawing and i update the .prt file the drawing will get automatically updated. so the forging drawing will show the machining features in the drawing.
My question is how to get them supperess for the forging drawing & keepactive for the machining drawing.
Please help
Abhinay
You may look at iPart for your forged part. This will allow you to "Step" each process and have a drawing for each machining process. Send me an e-mail and I will get the PDF to your that shows this work flow to turn your finished part into an iPart along with the step process to get a part for each forge and machine process.
blair dot stunder at arcticmfg.com
Since that is a simple part, I would -
Model the forged part.
Derive component the forged part into a new file.
Add the machining features to the derived component.
Do the drawings.
An alternative method
since you already have the machined part
derive the machined part into a new part.
Delete Face with Heal option to remove holes (and other cut features)
Add material where/if needed.
Do the drawings.
