Inventor Forum
how to place chains in assembly
8 REPLIES 8
Message 1 of 9
sam__gleeson
493 Views, 8 Replies
Hi
PLease how do i constrain the 4 chains from the frame to the centre ring.I have managed to get this far but need help continuing.Please see attached files
Cheers
Sam
8 REPLIES 8
Message 2 of 9
sam__gleeson
in reply to: sam__gleeson
Hi
It is possible for one of you much more experienced users to help me with constraining the chains....the reason i posted here is i thought that the forum was to help out users who need help.I appreciate any time given to help me understand how to do this process as this i know is a generous use of peoples time...I have managed to get this far but need help constraining the chains correctly from the frame to the centre ring
Sam Gleeson
Excel 2013 Edu
Message 3 of 9
JDMather
You are almost there.
Why didn't you connect the other 3 like the first?
Then connect to 4 points in the ring.
How precise do you need this to be?
You could use only Tangents in the last link in each chain.
I think I would then Ground everything.
Message 4 of 9
Winks87
Spoiler
Sam, the only way I have been able to add chains (or wire ropes) to an assembly was by creating a "static" part.  I projected edges and drew the chain from these at  the assembly level.
James Winkler
Message 5 of 9
Hi sam__gleeson,
I didn't take time to look at your files, but here is a link to a model that might help:
A set of links which are constrained to "fall" naturally from Cbliss.com
http://www.cbliss.com/inventor/Parts/Hardware/ChainLinks.zip
I hope this helps.
Curtis
Message 6 of 9
sam__gleeson
How precise: i just want it to assemble as if in real life..links not appearing half way through links , ring  etc...etc...
could you show me how you would assemble 1 chain ((only Tangents in the last link in each chain.
I think I would then Ground everything.))....i could then study the result and do the other 3 chains as my learning
Thanks Winks87
Thanks Curtis
Message 7 of 9
sam__gleeson
Regards
Sam
Message 8 of 9
JDMather
All 4 chains need to be constrained before grounding.
I forget - is there a reason you need this as separate parts assembly rather than as one part?
I did a search and found another thread on this topic
http://forums.autodesk.com/t5/Autodesk-Inventor/moveable-links/m-p/3742318#M457248
Message 9 of 9
sam__gleeson
No ,can this be done as 1 part...how would you do this as a single part?
