I have some doubts about Level of Details.
how to constraint the assembly in Level of detail mode.
i need suppress the features in position mode not in Level of Detail mode.
Linus kotte
Linus,
When it come to showing different suppression states LOD's are the only way to go I have found out.
If you are also using different constraints then you will probably have to create iparts/iassemblies.
Here is my own thread on Levels of Detail that might help you.
http://forums.autodesk.com/t5/Autodesk-Inventor/Disable-Level-of-Detail/td-p/3376691
Paul,
Thank you for suggestions of something new to look into. I have had many problems with LOD and things I have not been able to do with them. I will definately do some searching on view and positional reps.
Thank you
