sorry for my language
how to round off the visible surfaces inside ?
Welcome to the forum,
Are you talking about something other then using the fillet command?
What version are you using?
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Can you attach your *.ipt file here?
It might be easier to show with actual modeled geometry than to explain in words.
Looks like you would need to use a loft to create the body of your part. Which means you'd probably have to rebuild from the bottom. My part probably looks nothing like your actual part but I made something and attached it in case it helps.
Hi! I might be mistaken. The face is already tangent continuous to the adjacent faces. Why do you still need to create fillets?
I think, that's your wish. The yellow faces are concave.
Walter
Walter Holzwarth
Look at the feature tree.
But I'm just struggling with another version. I didn't consider the taper from 14.5 to 15.5 in Sketch1
Walter Holzwarth
I forgot R15 at the big end. Now added.
Walter Holzwarth
