Inventor Forum
how do I copy colors of surfaces w/ mirror/array command?
2 REPLIES 2
jpblower
401 Views, 2 Replies
I have an ipart I'd like to create w/ surfaces.  The surface color is important because we use that as plate thickness ID in FEA.  When I color a surface blue, then another red I continually get the default color when using the mirror or array command.  We're creating a customizeable ipart where there will be some intelligence surrounding how big the array (we may need 3, 4, or 5 beams based on the unit size).  I need a way that the colors on the surface propogate to the new surfaces created by the commands.
2 REPLIES 2
SteveMDennis
in reply to: jpblower
You are correct, we do not support this currently. It is certainly a known limitation that we have not implemented yet.
Can you search for this on Idea Station or create a new idea if one is not already there? Please give your example of how you would use it and what your expectations are.
We use Idea Station to gather a broad customer opinion and to prioritize our efforts in these smaller project areas.
Sorry for the limitation.
Steve Dennis
Sr. Principal Engineer
Inventor
Autodesk, Inc.
SER4
Looks like this was the created idea, however, it has been archived:
https://forums.autodesk.com/t5/inventor-ideas/keep-color-of-surface-using-array-mirror/idi-p/4597507
I'm on 2019 and still wishing this functionality worked.
Dell Precision 5680 Laptop; Win11 Pro; 64GB RAM; i9-13900H CPU; Intel Iris Xe Graphics, NVIDIA RTX 3500 Ada Laptop GPU.
Vault Pro 2023.4.1 (28.4.20.0); Inventor Pro 2023.4.1 (418).
